2001 Jeep Laredo ROUGH IDLE PROBLEM
CALIFORNIADAY
2001 Jeep Laredo (4.0 6cyl)
engine idling rough and it gets better when fully warmed up but does not go away. I have already replaced spark plugs, fuel filter, plug wires. Thanks.
Nov 9, 2009 at 11:26 AM
  • 110,251 POSTS
Have you checked for vacuum leaks? Also, has the check engine light come on?
Nov 10, 2009 at 5:18 AM
CALIFORNIADAY
[quote:19e7eac6e7="Jacobandnickolas"]Have you checked for vacuum leaks? Also, has the check engine light come on?[/quote:19e7eac6e7]
I did not locate any vacuum leaks and the check engine light is not on. Thanks for your help in advance.
Nov 12, 2009 at 3:24 PM
