2001 Jeep Laredo ROUGH IDLE PROBLEM
2001 JEEP GRAND CHEROKEE LAREDO
CALIFORNIADAY
2001 Jeep Laredo (4.0 6cyl)
engine idling rough and it gets better when fully warmed up but does not go away. I have already replaced spark plugs, fuel filter, plug wires. Thanks.
Nov 9, 2009 at 11:26 AM
  • 110,244 POSTS
Have you checked for vacuum leaks? Also, has the check engine light come on?
Nov 10, 2009 at 5:18 AM
CALIFORNIADAY
[quote:19e7eac6e7="Jacobandnickolas"]Have you checked for vacuum leaks? Also, has the check engine light come on?[/quote:19e7eac6e7]
I did not locate any vacuum leaks and the check engine light is not on. Thanks for your help in advance.
Nov 12, 2009 at 3:24 PM
