HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Grand Cherokee Laredo
Engine
Symptoms
Overheat
SPONSORED LINKS
2001 Jeep Laredo overheating
MMAIO81
MEMBER
2001 JEEP GRAND CHEROKEE LAREDO
6 CYL
4WD
AUTOMATIC
120,000 MILES
When a/c is turned on engine will overheat.
Friday, August 7th, 2009 AT 4:24 PM
MECHANIC
Is the AC condenser fan coming on -to include the radiator fan?
SPONSORED LINKS
Friday, August 7th, 2009 AT 4:28 PM
MMAIO81
MEMBER
The fan comes on with the a/c, but the fan doesn't look original. Could it be too weak to cool the a/c and engine?
Friday, August 21st, 2009 AT 4:13 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
2001 Jeep Laredo Overheating
Overheating Changed Thermostat
Asked by
mjdaelf
2001
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
2001 Jeep Laredo Overheating.
The Other Day I Was Driving My Jeep I Just Bought And I Noticed My Air Conditioning Stopped Working And It Was Blowing Out Warm Air. Then...
Asked by
bessiemay
2001
1999 Jeep Laredo Car Overheating
My Car Only Overheats If I'm Idling In Trafffic For More Than 10 Minutes. Once I Start Moving My Therostat Gauge Starts To Go Down And It's...
Asked by
jl2walk
1999
1995 Jeep Laredo Overheating????
In My 95 Grand Cherokeei Have Replaced The Waterpump, Radiatior, Thermostat, And Clutch Fan. It Was Running At About 250 Degrees, But It...
Asked by
kawi128
1995
2002 Jeep Laredo Engine Overheating
The Malfunction Indicator Light Came On And Oil Was Leaking From The Valve Cover Which The Gasket Was Replaced. The Oil Damaged The Starter...
Asked by
ldelgado
1 ANSWER
2002
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Online car repair manuals
