2001 Jeep Laredo No spark in Spark Plugs
99,999 MILES • 6 CYL • 4WD • AUTOMATIC
VEROGHEO
On my way back from work, the car worked fine.
The next day the car will not start. I crank and crank but the car will not start. I have changed the spark plugs with new ones, i have also changed the ignition coil, there is electricity in Battery ( all electric appliances work, like windows, and radio). I have fuel in the fuel tank and the fuel pump works and i have also checked the Fuses and none of them are burned out.
I can not find the problem with my car.
I can not find a reason why the car will not start.
I have a 2001 Jeep Laredo Grand Cherokee, 6 cyl 4 wheel drive.
Please can someone explain to me why my car is not starting? What is wrong with it?
Oct 15, 2008 at 10:22 AM
JNOVACK
  • 723 POSTS
three things are needed to make car run spark compression and fuel check for spark using a spark tester can get anywere cheep then check fuel pressure and then compression and please let me know what you come up with and I can go from there thank you
Oct 15, 2008 at 11:01 AM
