2001 Jeep Laredo Fan stopped
2001 JEEP GRAND CHEROKEE LAREDO
71,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEFFJ44
Hi...My Jeep Laredo started to over heat today.....enough, coolent, no leaks....the fan has stopped....it is not seized up, spins freely...how do I tell what sensor needs to be replaced?
Aug 15, 2008 at 12:48 PM
BLACKOP555
  • 10,386 POSTS
take the coolant temperature switch and put it on direct +12v if the fan doesnt turn on then the relay has failed or the fan has failed even a damage in the wiring harness.
if it turns on the switch or voltage to it is failing.
Aug 15, 2008 at 3:23 PM
