2001 Jeep Laredo engine overheates while at a stop
MICHAEL.D.BRACE
Engine Cooling problem
2001 Jeep Laredo 6 cyl Four Wheel Drive Automatic
I replaced the temperature senser and now suspect that the fan or the fan relay may be faulty? The jeep only gets hot when sitting still for a short time, while moving the temp is normal.
Mar 29, 2010 at 11:54 AM
BEEF99
  • 152 POSTS
This is a good indication that your water pump is bad and needs replaced and while you are at it, replace your t-stat too.
Mar 30, 2010 at 2:07 AM
