2000 Jeep Laredo Weep Hole?
2000 JEEP GRAND CHEROKEE LAREDO
103,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIKERBABETC
I THINK MY WATER PUMP MAY BE GOING. I JUST NOTICED THAT DOWN ON THE BOTTOM PART OF THE ENGINE, THERE IS A SMALL HOLE THAT LOOKS AS IF WATER IS COMING OUT OF IT WHEN I STOP.
I'M NOT SURE. IT LOOKS AS IF THERE SHOULD BE A HOSE THERE BUT MAYBE THAT IS WHAT YOU CALL THE "WEEP HOLE."
DO YOU CARRY WATER PUMPS FOR THIS VEHICLE? THE VIN# 1J4GW48S2YC149234 6 CYLINDER
REBUILD _ $
NEW_ $
THANK YOU!
Oct 7, 2008 at 4:23 AM
REDJEEEP
  • 29 POSTS
[quote:5ca6fa7f64="bikerbabetc"]Engine Cooling problem
2000 Jeep Laredo 6 cyl Four Wheel Drive Automatic 103000 miles
REBUILD _ $
NEW_ $
THANK YOU![/quote:5ca6fa7f64]
Yes it is a weep hole . if you see colant leaking from thier its time to replace the water pump price for the pumps are cheep auto zone has them for no more than 30 dollars with a life tim garanatee
Oct 31, 2008 at 6:59 AM
