2000 Jeep Laredo thunking
14,000 MILES • 6 CYL • 4WD • AUTOMATIC
TM14701
I've got a thunking noise when going over rough roads, I've had the upper and lower ball joints replaced and the tie rods replaced. I still hear the same noise, what could it be?
Mar 10, 2010 at 12:52 AM
BEEF99
  • 152 POSTS
My Jeep had similar problems and found that my front sway bar bushings were worn and had to replace them. Take a look at them and if they are torn or worn too much, replace them. I am assuming that the thunk is only when you hit bumps or whatnot and not all the time.
Mar 10, 2010 at 9:51 AM
TM14701
yes it's only when I'm on a rough road. thank you
Mar 10, 2010 at 2:35 PM
