2000 Jeep Laredo struts
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
NAPAJEEPSTER
Just wanted to get a ballpark estimate on the front end strut replacement cost.
Jan 11, 2009 at 8:18 AM
JNOVACK
  • 723 POSTS
you have shocks and it is easy to do the job your self and the shocks cost between 17.00 and 60.00 your choice there is one bolt on top all you do is put a socket on it with a long extention and by hand move it back and forth till it breaks off the go under and unbolt the 2 bolts on the bottom and put the new ones in and tighten the bolts and your done
Jan 25, 2009 at 7:15 AM
