2000 Jeep Laredo Seats
2000 JEEP GRAND CHEROKEE LAREDO
121,000 MILES • V8 • 4WD • AUTOMATIC
RSDTGT
Driver & Passenger seats both move forward and back but not up-down-forward-backward tilt or any other movement. When using switch there are sounds from each. Sounds like notch or gear slippage. Maybe if i could see mechanisim I could tell. If so do I have top remove the seat and how?
Maybe better to go to dealer. Any idea of a reasonable repair cost? Thanks, Ron
Sorry I'm on a limited income.
Sep 4, 2010 at 10:28 AM
2 LINSEY
  • 287 POSTS
Hi rsdgt, if you can hear a noise when you push the switch then you can rule out the switch being bad. I would say that it is probally going be a case where the seat will have to be removed and inspected. As for repair cost for this I would expect to pay about 1 hour labor for the diagnosis and depending on what the cause of the problem is expect to pay between 1-2 hours labor for the repair plus parts. its only 4 nuts and a couple of plugs to remove the seat and you might be able to see the problem and fix it your self. Good luck!!
Sep 13, 2010 at 7:30 AM
