2000 Jeep Laredo Coolant leak
146,000 MILES • V8 • 4WD • AUTOMATIC
LABERTRAY
I have been fighting with my car and the coolant for sometime now. I have replaced everything that could be replaced that relates to the coolant. I have a leak that seems to come and go. Sometimes the coolant poors out of the car and the next time there might be a few drips. Ihave replaced the radiator and it stopped momentarily, however came back a short time later. Could something be stuck open allowing the coolant to escape? It seems to drip from up by the radiator, however the other day I got to work at 6am and all the coolant leaked out of my car, I noticed this at 11:30 when I went out to get something. So, I filled the resevior tank with more coolant, so I did not have to worry about it later (as it has never leaked before while the car was not being driven) and I came back out at 3 and all the coolant had again leaked out... So I added more and drove home and maybe about 10 drops came from the car all night. Even after cooling off. This is very frustrating since I have replaced so many things (radiator, water pump, thermostat...etc) What else could be causing this leak...Did I get a defective radiator? COuld it be a thermostat problem and the coolant is being pushed out from somewhere because the thermostat does not open/close? Please help
Aug 5, 2008 at 6:38 AM
JNOVACK
  • 723 POSTS
1 Inspect Water Pump Damaged, worn or leaking water pump.
2 Inspect Water Outlet Cracked or leaking water outlet.
3 Inspect Radiator Cap Worn or damaged radiator cap
4 Inspect Heater Control Valve Leaking or defective heater control valve.
5 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose.
6 Inspect Radiator Rusted, corroded, or damaged radiator may be leaking antifreeze/coolant
7 Inspect Radiator Drain Plug Loose, damaged, or faulty radiator drain plug.
8 Inspect Head Gasket - Performance Blown head gasket
9 Inspect Freeze Plug Freeze plugs are cracked or leaking
Oct 12, 2008 at 9:49 AM
