2000 Jeep Laredo Brake Noises
2000 JEEP GRAND CHEROKEE LAREDO
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
ADLINDSAY
Whenever I step on the brakes or put the engine in gear (while stepping on the brake pedal), the brakes make this squeaky kind of sound. I have had the brake pads replaced within the past year and hear no air in the system when pressing on the brakes. What could be the cause of this?
Sep 3, 2009 at 6:38 AM
  • 110,244 POSTS
The noise from the brakes is most likely caused from a glaze that was built up on the rotors prior to having the brakes replaced. If the mechanic only replaced the pads and did nothing to the rotors, then have them removed and slightly cut to clean the glaze off them. Then take the new brake pads and with sand paper, sand the glaze from them. That should get rid of the noise.
Let me know if this helps.
Nov 9, 2009 at 3:27 AM
