2000 Jeep Laredo baptist
2000 JEEP GRAND CHEROKEE LAREDO
12,345 MILES • V8 • 4WD • AUTOMATIC
BAPTIST2091
where is the starter and can you show a picture of where its at in the engine
Feb 14, 2008 at 10:58 AM
JNOVACK
  • 723 POSTS
it is under jeep on right side back of motor has red battery cable and two other smaller wires.
Removal & Installation
3.7L And 4.7L Engines
Disconnect and isolate negative battery cable.
Raise and support vehicle.
Note: If equipped with 4WD and certain transmissions, a support bracket is used between front axle and side of transmission. Remove 2 support bracket bolts at transmission. Pry support bracket slightly to gain access to lower starter mounting bolt.
Remove two bolts if equipped with an automatic transmission.
Move starter motor towards front of vehicle far enough for nose of starter pinion housing to clear housing. Always support starter motor during this process, do not let starter motor hang from wire harness.
Tilt nose downwards and lower starter motor far enough to access and remove nut that secures battery positive cable wire harness connector eyelet to solenoid battery terminal stud. Do not let starter motor hang from wire harness.
Remove battery positive cable wire harness connector eyelet from solenoid battery terminal stud.
Disconnect battery positive cable wire harness connector from solenoid terminal connector receptacle.
Remove starter motor.
Starter mounting—3.7L and 4.7L engines
To install:
Connect solenoid wire to starter motor (snaps on).
Position battery cable to solenoid stud. Install and tighten battery cable eyelet nut . Do not allow starter motor to hang from wire harness.
Position starter motor to transmission.
If equipped with automatic transmission, slide cooler tube bracket into position.
Install and tighten both bolts .
Lower vehicle.
Connect negative battery cable.
Oct 12, 2008 at 10:13 AM
