2000 Jeep Laredo 4.7Liter V8 RPMs surge
130,000 MILES • V8 • 2WD • AUTOMATIC
RD4813
  • 5 POSTS
RPMs tend to surge to over 1,000 when stopped at traffic light/stop sign. Does not happen all the time.
Jan 31, 2008 at 11:23 AM
MERLIN2021
  • 17,250 POSTS
If the check engine light comes on get the code read...post it here, if no light You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Feb 5, 2008 at 1:54 AM
RD4813
  • 5 POSTS
Check engine light is not on. Checked for vac leak as suggested, none found. Other suggestions?
Feb 8, 2008 at 12:44 PM
MERLIN2021
  • 17,250 POSTS
When was the last full tune up? Fuel and air filters? Clean throttle body? Plugs...
Feb 9, 2008 at 1:56 AM
