2000 Jeep Laredo
70,000 MILES • 4 CYL • 4WD • AUTOMATIC
ESKINNER
My GC will roll when in park and the reverse will not work. You can feel it go into reverse but it does not move right when you press the gas.
I have an extended warranty and took it to the dealer. The first thing the warranty co asked was if i did the 60000 mi maintenance. I did not but did a 4x4 fluid maintenance. The now want 400 to tear down the tranny and they are going to send out an inspector to check to see if the issue was maintenance related. The dealer said there was metal particles in the pan and he believes the torque converter needs replacing. He said the tranny needs to be rebuild at a price of 2600 - 3000. I asked which codes were produced and he said there were no codes. I have a funny feeling about this place and I would like some elses opinion. Please let me know what the problem could be and if youthink I should get a rebuild.
Thank you very much
Oct 28, 2008 at 5:43 AM
REDJEEEP
  • 29 POSTS
yup its now time for a rebuild the 60 k service does matter a little when was the last time you had your trand fluid changed thats all they need to know
that trans does not produce many codes because its more opperated by fluid rather than eltronics most of the time you would loose a foward gear first but due to the way the trans works low/reverse gear is together the price seems a little high you can get a reman trans for a better price with a better warrenty
Nov 1, 2008 at 4:13 AM
ESKINNER
Hi guys,
Thank you for the advice. It turns out the Dealer in this case went to bat for me with my warranty company and they are covering the repairs! Yea!! I am so happy that they stood behind their work and Many Many thanks to the Lance ad the Jeep Dealership in Casseberry for getting it done!
Thanks again for your advice.
Take Care,
Ed
Nov 1, 2008 at 4:40 PM
