MSPIGOT
Electrical problem
2000 Jeep Laredo 6 cyl All Wheel Drive Automatic
don,t have owners manual....cruise went out and don't know which fuse the cruise control is on and it is not listed on either fuse box. cann you help
Oct 18, 2008 at 3:30 AM
MERLIN2021
  • 17,250 POSTS
Not so easy! Controlled by the VSS and BCM, Try reading codes, then post any that come upo, here's how: Turn the key on (to acc) then off three times any codes in memory will display on the electronic odometer display on the dash. No code reader required!
Oct 19, 2008 at 1:30 AM
