2000 Jeep Grand Cherokee
2000 JEEP GRAND CHEROKEE LAREDO
ABCAUTO
  • 11 POSTS
While driving down the road at about 75 mph the vehicle at night, the vehicle shut off and the lights went out. It started back up after turning the key on and off a couple times. A day or two later it started to shut down again and this time it caught itself while coasting to a stop. Another day I cranked and cranked before it finally fired,,,, this has only happened once.(maybe not related)
Mar 26, 2010 at 5:47 PM
BEEF99
  • 152 POSTS
Try this before anything else, with your vehicle running, wiggle the plug wires going into your ECU (computer under your hood) and wiggle your ECU, if your vehicle stalls during the wiggling, take the three plugs off and replace them with slightly shorter ones as they are too long and shorting out your ECU. Also, make sure no corrosion are on the pins and the reciever of the plug pins and add dielectric grease in a small amount to the pins before plugging back in.
If your vehicle does nto stall, that is not your problem and let us know if u need further help. Thanks for stopping in the to site!
Mar 26, 2010 at 6:58 PM
