2000 Jeep GC Laredo - rear axle bearing
KRISTI ABBOTT
We are trying to remove the rear axle bearing seal- there is a sleeve before we can get to the seal- can you remove it without a press?
May 27, 2007 at 8:38 AM
REDJEEEP
  • 29 POSTS
[quote:9c15f86f69="Kristi Abbott"]We are trying to remove the rear axle bearing seal- there is a sleeve before we can get to the seal- can you remove it without a press?[/quote:9c15f86f69]
yes its called a retainer ring if your good with a cut off tool you can cut in to it on a vertical line dont cut all the way through after your about 80 % of the way through hit it in the cut aeria with a chisle and a hammer NOTE you will need a press to put it all back to gether
Oct 31, 2008 at 7:21 AM
