1999 Jeep Laredo Rear Brakes
SVDOOLEY
Brakes problem
1999 Jeep Laredo 6 cyl Four Wheel Drive Automatic
Where are the bolts located to remove the brake pads and what size are they. Can you direct me to a diagram or video removing the rear brakes on a 1999 jeep grand cherokee laredo
Aug 10, 2009 at 10:21 AM
  • 110,246 POSTS
Sorry, I don't have a picture. However, there are two bolts in the rear of the caliper. Chances are you don't see them because they are covered by a (black) rubber dust cover. Look closely and you'll see the dist covers. In them are the bolts. As far as size, some are 10mm, some use an allen wrench, and others use a torx.
Check this video
http://www.youtube.com/watch?v=3UkRUz5xXL0
Feb 11, 2021 at 1:52 AM
