I just replaced the radiator in my 1999 Jeep Grand Cherokee. After everything was put together all was fine except the cooling fan would not run. I turned on the AC and let it heat up to operating temp and still wouldn't work. I checked the voltage coming from the relay connector to the fan and had 12.8 volts. I bypassed the connectors and still it would not operate. I ran it to the battery and it ran fine. What could be the problem?
Nov 14, 2008 at 12:50 PM
