1999 Jeep Laredo IGNITION locking cylinder
1999 JEEP GRAND CHEROKEE LAREDO
MADANNING
Interior problem
1999 Jeep Laredo 6 cyl Four Wheel Drive Automatic
How can you remove the ignition locking cylinder if the key will not turn?
May 24, 2010 at 5:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
If the lock cylinder is in the ACC position you can replace it by removing the column covers and accessing the release button. If it's completely in OFF / LOCK position you may have to drill out the lock cylinder to replace it.
May 24, 2010 at 8:43 AM
