The ABS light and brake light are both on--what does this mean?
Sunday, December 14th, 2008 AT 4:15 PM
REDJEEEP
MEMBER
Please check your brake fluid first. If it is low that will cause both lights to go on. The only other thing it could be is that you need a wheel sensor but you should fix the brake light first. Top off the fluid and let me know how you make out well figure out the rest
