1999 Jeep Laredo
LALAYLEO
  • 5 POSTS
Engine Mechanical problem
1999 Jeep Laredo 6 cyl Two Wheel Drive Automatic
i was wondering how to set the timing on it?
Mar 26, 2010 at 5:11 AM
DOCFIXIT
  • 18,828 POSTS
Ignition timing controled by PCM no adjustment can be made.
Mar 26, 2010 at 5:27 AM
LALAYLEO
  • 5 POSTS
there is compresion , there is spark , gas but it wont start, it cranks over but wont start... what can i do now???
Mar 26, 2010 at 6:02 AM
DOCFIXIT
  • 18,828 POSTS
Spark must be a blue/white flame fuel pressure must be 44-54 psi. What happened ? come on sudenly/ or been runnig bad prior?
Mar 26, 2010 at 6:11 AM
LALAYLEO
  • 5 POSTS
i jus replaced the motor the old one had bad bearings but it was running.
Mar 26, 2010 at 6:20 AM
DOCFIXIT
  • 18,828 POSTS
Same year and size? everything hooked up?
Mar 26, 2010 at 6:25 AM
LALAYLEO
  • 5 POSTS
yes,everything is hooked up..
Mar 26, 2010 at 6:29 AM
