1999 jeep grand cherokee laredo shaking when braking
JIMMYKAMP
106000mi 4.0L 6cyl I have been having a problem with my brakes. The problem is i brake just fine above 60mph and below 45mph it is when i am between there that it occurs. It is almost like the car is going to fall apart sometimes. my jeep begins to shake, the steering wheel and it looks like the front end is shaking as well. Sometimes it is a violent shake most of the time it is just a slight shake. all i have to do is let off the brake and allow it to slow down and reapply the brake if there is anyway that you can help me with this problem it would be much appreciated.
Sep 14, 2007 at 12:14 PM
MERLIN2021
  • 17,250 POSTS
Well if I owned it I would see if Autozone has a runout gauge I could blorrow and I would check the rotors front and rear...unless you are at the stage you need brakes! then just go ahead and buy new rotors...
Sep 15, 2007 at 12:41 AM
