1998 Jeep Laredo water noise
112,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALAN SLOTNICK
a water sloshing in the dashboard
Oct 13, 2008 at 10:09 AM
REDJEEEP
  • 29 POSTS
[quote:02d497fc46="alan slotnick"]Noises problem
1998 Jeep Laredo 6 cyl Four Wheel Drive Automatic 112000 miles
a water sloshing in the dashboard[/quote:02d497fc46]
There is a tsb for this problem the heater box drain is cloged If you pull back the passanger side carpit you sould see a black box that turns in to the shap of a v
and a circle at the bottom . if you drill a small hole in the center of the circle and use a coat hanger ti push through the new drilled hole work it back and fourth a few times and check underneath the jeep for a poddle of water. then tack some rtv and fill the hole so water dont leak into the jeep. when toy here that noise again just repeat the steps with out the drilling
Oct 31, 2008 at 7:10 AM
