I have a 1998 Jeep Grand Cherokee, 6 cyl, 4.0L, fuel injected. I'm unable to start the engine. When key is in ON position, all lights (engine check stuff) on the dash lightup as normal, but no gauges move. When I put key into start position, the engine cranks over as normal, but does not start. It does not even attempt it. I suspect spark or fuel electrical. I've checked fuses in the engine compartment, all fine. The vehicle ran fine this morning to work and now I'm stuck at work. Where else can I look for in the jeep? What else could be the porblem? Thank You!
Jan 19, 2010 at 7:33 AM
