1998 Jeep Laredo proplem starting car
205,000 MILES • 4 CYL • AWD • AUTOMATIC
BPOULSEN2005
when i start the car in the morning its starts right up. if i drive the car for any leghth of time more than 10 minutes and shut the car off, it won't start again. if i sit and wait for about 20 minutes then it will start again.help!please its frustrating.
Jun 27, 2010 at 9:10 AM
  • 75,988 POSTS
Next time it refuses to start-don't wait for anything- do below for a start to determine if its fuel or spark related issue and get back with some results.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jun 27, 2010 at 12:26 PM
