1998 Jeep Laredo please help
DMDAMMANN
Engine Cooling problem
1998 Jeep Laredo 4 cyl Two Wheel Drive Automatic 150 k miles
On my way to work this morning the car was running a bit rough. At the third stop light, it died, and barely started again. I pulled over, checked the fluids. All good as far as I know. Got it started again and drove home.(about 1.5 miles) During this time, I had the heat turned on, but it was blowing cold air. By the time I got there, there was steam/white smoke billowing out from around the radiator area, and lots of hissing. I had filled the radiator yesterday, but failed to secure the cap all the way. Any Suggestions? Much appreciated
Sep 28, 2008 at 9:37 AM
BLACKOP555
  • 10,386 POSTS
did the vehicle overheat?
does it still start now?
check to make sure no wirings or sensors are wet with coolant and shorting out.
Sep 28, 2008 at 1:39 PM
