1998 Jeep Laredo Coolant Lines
1998 JEEP GRAND CHEROKEE LAREDO
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
AUSTINLJONES
Hey guys, I have a 98 Jeep Grand Cherokee and I need to replace the transmission cooler lines. The existing lines were butted up against the exaust and melted through the cooler line/s. So now my car is leaking transmission fluid. How much would you say is fair price for replacing these lines if I were to take it to a shop or a dealer?
Aug 25, 2010 at 1:30 AM
  • 110,244 POSTS
The lines should be steel. Have they rubbed a hole?
Aug 25, 2010 at 2:19 PM
AUSTINLJONES
They may have rubbed a hole. I just spotted a part in the line where it was up against the exhaust pipe and the cooler line was dented in. That also seems to be where my fluid is coming from so I just assumed it melted. Is that not a common problem?
Aug 25, 2010 at 2:28 PM
  • 110,244 POSTS
No, it really isn't common. The lines shouldn't be touching anything. As far as replacement, if you find a factor direct fit part, expect to pay around 50.00 for it and allow about an hour for labor.
Aug 26, 2010 at 12:40 AM
