1998 Jeep Laredo Check Guages light comes on and battery ne
1998 JEEP GRAND CHEROKEE LAREDO
10,200 MILES • 6 CYL • 4WD • AUTOMATIC
FREDDIEP
Help!!,
I have replaced the battery, alternator and battery post connection cables. After turning on, the check guages light comes on and the battery indicator needle drops to negative. Sometimes it reverses but most times not. The cars does not stop or cut off and if I cut off the engine it will restart but I am afraid it wont. I have also noticed that when I turn on the windshield wippers the radio changes and the interior lights blink... Help Please
Thank you,
Fredrica
Oct 22, 2009 at 4:34 AM
JDL
  • 16,098 POSTS
Welcome, I'd have to check charging system voltage. Use digital voltmeter, take reading across battery posts, everything turned off. A full charge is around 12.6 volts. Next, start the vehicle, take a second reading across battery post. The second reading should be higher than the first. If it is the charging system appears to be working. Can't tell about the instrument cluster gages?
Oct 22, 2009 at 5:03 AM
