1998 Jeep Grand Cherokee, 109K mi, 6-cyl, Check Gauges light
1998 JEEP GRAND CHEROKEE LAREDO
SNUFFY44
The "Check Gauges" light came on for the first time. The volt-meter guage was pegged to the right (+) and stayed there for about 4 minutes. The guage then returned to the center/neutral position and wavered a bit more then usual, but stayed in the normal range. I cleaned the battery terminals and the car was able to start with normal gauge indications.
Just checking to see if this is an indication of an alternator issue or possibly a voltage regulator.
Thank you!
Sep 28, 2007 at 10:43 AM
BMRFIXIT
  • 19,053 POSTS
[quote:ac162114e4="snuffy44"]The "Check Gauges" light came on for the first time. The volt-meter guage was pegged to the right (+) and stayed there for about 4 minutes. The guage then returned to the center/neutral position and wavered a bit more then usual, but stayed in the normal range. I cleaned the battery terminals and the car was able to start with normal gauge indications.
Thank you![/quote:ac162114e4]
The alternator diode or the voltage regulator
both are what they call built in so its part of the alternator
I would have the alternator checked !!
good luck2
let us know
Sep 28, 2007 at 12:08 PM
