1998 Jeep Laredo AC DRAIN LINE
1998 JEEP GRAND CHEROKEE LAREDO
127,000 MILES • 6 CYL • 4WD • AUTOMATIC
DOB727
The AC drain line is clogged and backing up into the passenger side floorboards mostly in the passenger rear.. The AC itself is working OK, just added freon..
Trying to figure where/how to unclog the drain line. I understand it may run under the frame of the Jeep?? Please assist.
Jun 23, 2009 at 10:40 AM
  • 110,194 POSTS
Check on the firewall under the hood (passanger side). It will be a black rubber hose. Usually they plug near the end. Move it around or try placing a piece of wire in it to clean it out.
Jun 29, 2009 at 11:16 PM
