1998 Jeep Laredo AC Drain Line
DOB727
  • 1998 JEEP GRAND CHEROKEE LAREDO
  • 6 CYL
  • 4WD
  • 127,000 MILES
The AC dain line is clogged and backing up into the passenger side rear floorboards. I understand the drain line may run under the vehicle's frame on that side? Please advise as to the best way to unclog the drain line. 98 Jeep Grand Cherkee Laredo 6 cyl 4WD. Thank you.
Wednesday, June 24th, 2009 AT 9:59 AM
RACEFAN966
  • 5,029 POSTS
Ok it will come out of the firewall on the passenger side. It will look like a black rubber tube about 1" in diameter and pinched together to keep stuff from getting into it from outside. Now what I would do is a coat hanger and straighten it and open the tube and see if you can get anything out of it. If you don't find it let me know I will look at my Jeep and get a pic of it for you.
Wednesday, June 24th, 2009 AT 10:14 AM
DOB727
Is the hose near the bottom of the firewall or more towards the top? I appreciate the help.
Wednesday, June 24th, 2009 AT 10:34 AM
RACEFAN966
  • 5,029 POSTS
It should be about 3/4 the way down on the passanger side. It should look something like the pic below.
https://www.2carpros.com/forum/automotive_pictures/249564_images_1.jpg
Thursday, June 25th, 2009 AT 8:54 AM
DOB727
Thanks.
Thursday, June 25th, 2009 AT 9:19 AM
RACEFAN966
  • 5,029 POSTS
You are welcome. Let me know how it goes and if you have any more questions just ask. Thanks for you support.
Friday, June 26th, 2009 AT 9:25 AM
