1997 Jeep Laredo Rear end??
1997 JEEP GRAND CHEROKEE LAREDO
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
NICKPETRICH
I have a 1997 Jeep Cherokee Laredo and it started to make a whinning/howling noise in the rear. So i checked fluid and it was low. What could be wrong??? Is it an easy/cheap fix to do yourself????
Oct 28, 2009 at 10:55 AM
  • 110,244 POSTS
Are there any leaks? Did you check the axle seals? Is the differential cover leaking? Did you refill the differential?
Nov 9, 2009 at 1:33 AM
