1997 Jeep Laredo PITMAN ARM
100,200 MILES • 4 CYL • 4WD • AUTOMATIC
KC4LIFE34
WHY WOULD POWERSTEERING FLUID BE LEAKING FROM BETWEEN MY STEERING GEAR AND THE PITMAN ARM .. AND HOW CAN I REPAIR THIS
Aug 1, 2008 at 9:54 AM
MERLIN2021
  • 17,250 POSTS
If the leak is from the bottom of the sector shaft, there is a repair ket, available at the dealer. comes with new seals and bushings. I remove the pitman arm, with a pitman arm puller, then remove the snap ring, then either use a seal remover, or start the jeep and turn the wheel and shut it off fast, have a bucket under the shaft to catch the seals bushings and fluid, now just instal the new parts.
Aug 1, 2008 at 10:00 AM
