1997 Jeep Laredo leak
TRAVIS54
  • 1997 JEEP GRAND CHEROKEE LAREDO
  • 6 CYL
  • 175,000 MILES
I have 97 jeep grand cherokee with coolant leak at front of engine cant tell where maybe water pump could it be cracked head or freeze plug if there is one in front if so how can I tell
Sunday, December 27th, 2009 AT 6:28 PM
BEEF99
  • 152 POSTS
If it is the 4.0 engine, they are known for water pumps and radiator issues. Your water pump has a weep hole behind the pulley, check to see if there is any fresh moisture around that weep hole. If your engine has a lot of oil and dirt on it, take it to pressure wash it at a car wash and put engine degreaser on it before cleaning. Then after cleaning, check the weep hole for moisture after a couple of days. To check the radiator, look at the radiator from all directions possible for any fluid leaks and corrosion. Also, look at all your hoses for any pinholes by the clamps or any soft spots in the hoses. If it was a cracked head. More than likely you would not be driving it. Also, if it was a freeze plug, they usually either go completely or not at all and I have never had one go on a Jeep before.
Sunday, December 27th, 2009 AT 6:58 PM
