1997 Jeep Grand Cherokee Laredo-110K
1997 JEEP GRAND CHEROKEE LAREDO
GEORGEB
I have a problem with intermittent hesitation and stalling. Car does start back up right away.Did tune-up.Does it Hot or cold.Some days runs fine,seems like mind of its own.No check engine light. One day car acted up and engine light came on.code for ignition coil.replaced ignition coil ran fine that afternoon.Thought problem was fixed,next morning hesitation and sometimes stalls but normally can keep it going giving it gas.Not getting any additional codes when this occurs. Could this be oxygen sensor?? Any suggestions or comments would be very helpful.
Jul 6, 2007 at 4:39 AM
GEORGEB
Im updating to my own question regarding this issue.After reading several forums and other problems. I replaced the ICM-Idle control motor it seem better but there was still slight problem still. I then replaced TPS-throttle position sensor recommened by local mechanic. Well its been 24 hours and 2 trips back and forht to work. Not one single problem. Normally it would have done something. I will give it another 3 days and will update that this problem is officially fixed. :)
Jul 13, 2007 at 6:07 AM
