1996 Jeep Laredo stalling
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
DARREL BILL
i have a 96 jeep grand cherokee larado 4.0 and i have replaced the fuel pump-filter, aic, tps crank sensor ingition coil, cap - rotor, distributor coolant sensor. when i start it it stalls after a little while sometimes it starts back up sometimes it wont it will just crank over but not starting. i am at my ends with this jeep. sometimes it will run fine one dayand then it will stall on the highway the next. any sugestions.
Jan 18, 2008 at 7:17 AM
  • 75,988 POSTS
Did you check the fuel pressure after you've installed the fuel pump. If it has an auto shut down relay inspect and test it.
When you 1st turn key to On -do you hear the fuel pump for a few secs ?
Jan 18, 2008 at 8:13 AM
DARREL BILL
yes i took it back to the repair shop after i put a new feul pump in and they said it had good pressure now. yes i can hear the pump running when trun the key to the on postion. can it be the tranny going bad causing it to stall.
Jan 19, 2008 at 6:10 AM
  • 75,988 POSTS
What was the fuel pressure reading and does it has an injection pulses in order for the cylinders to receive fuel.
The engine will fire-up by itself and continue to run without a transmission
Jan 19, 2008 at 12:10 PM
