1996 Jeep Laredo shakes after hits pothole or bumps
JODEL
Shakes or Wobbles problem
1996 Jeep Laredo 6 cyl Four Wheel Drive 200220 miles
when driving on the highway doing 50 to 60 mph, when i hit a bump or pothole the car shakes, i would have to literally stop short on the high way to stop it...almost got rear ended a couple of times
what's done so far ?
replaced upper and lower ball joint on both side, the U-joint
still there...what should i check / do next
Apr 7, 2010 at 4:34 PM
DOCFIXIT
  • 18,828 POSTS
Need to replace steering damper
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_442.jpg
Apr 9, 2010 at 4:41 AM
JODEL
Replaced the steering damper fix the problem for 2 days, now i am having the same shaking again...whatz next
Apr 19, 2010 at 4:34 AM
DOCFIXIT
  • 18,828 POSTS
Check tie rod tube to track bar ends for play should be zero
Apr 19, 2010 at 9:29 AM
