1996 Jeep Laredo noises from the driver side front tire
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DWAYNE RUSSELL
I" getting noises from around the front driver side tire, someone said it's the cv drive shaft. However I have yet to locate a cv drive shaft. my question is where is the cv drive shaft? On my model car?
Nov 10, 2008 at 1:01 AM
JNOVACK
  • 723 POSTS
you don't have a cv joint on yours because yours is 2 wheel drive now is this noise when you hit a bump or just driving if it is when driving what your hearing is the hub bearings they are easy to replace if you need I can talk you through it if it is when you hit a bump then it is a ball joint
Nov 14, 2008 at 11:18 AM
