1996 Jeep Laredo ENGINE WELL NOT STARD
108 MILES • 6 CYL • 4WD • AUTOMATIC
LORETO
I HAVE A 1996 CHEROKEE LAREDO I TRYING TO GET IT TO RESTART RUN THEN AFTER ABOUT ANOTHER 1 MINUTE IT DIED AGAIN WHAT IS THE PROBLEM OF THIS CHEROKEE LAREDO?
Dec 15, 2007 at 12:15 PM
BLACKOP555
  • 10,386 POSTS
does it fire right back up after it dies out or do you have to let it sit for about 4-5hours before it fires back up and runs for 1 minute, sounds to me like a bad fuel pump,
check the fuel pressure at the fuel rail, or try starting fluid, if it keeps running untill you stop giving it starting fluid then your problem probably is a restricted fuel filter, low fuel, or bad fuel pump.
Dec 15, 2007 at 2:04 PM
