1996 Jeep Laredo brake light fuse blowing
1996 JEEP GRAND CHEROKEE LAREDO
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
COLDILLINI
None of my brake lights work because of a blown fuse. I replace the fuse and the lights work but when I push the brake pedal, the fuse blows again. What do I need to look at to fix the problem or do I need a mechanic with more testing equipment to find a short in the circuit. Everything else is currently working
Apr 12, 2008 at 2:50 PM
BMRFIXIT
  • 19,053 POSTS
you can start by checking the light bulbs
and its connections
and check the wiring
for tools
volts meter or test light
Apr 12, 2008 at 3:00 PM
