1995 Jeep Laredo TRANSMISSION NOT WORKING
1995 JEEP GRAND CHEROKEE LAREDO
HOTAIR
Transmission problem
1995 Jeep Laredo V8 Four Wheel Drive Automatic
,i WAS DRIVING HOME UP SIGNAL MOUNTIAN WHEN I FELT MY JEEP JERK VERY LIGHTLY TWO TIMES,THEN NOTHING ELSE HAPPEND UNTIL I WAS ALMOST TO THE TOP,THEN MY JEEP WOULD NOT GO ,I DIDNT HAVE ANY GEARS, NOT DRIVE OR FIRST OR REVERSE,iI COASTED BACK DOWN TO A PULL OFF AND LEFT IT UNTIL THE NEXT DAY WHEN I HAD IT TOWED HOME,AFTER I GOT IT HOME I STARTED IT UP PUT IT IN DRIVE AND IT MADE A NOISE LIKE A RUBBING OR LOW GRIND,BUT IT PULLED FORWARD ,IT MADE THE SAME NOISE IN REVERSE AND MOVED BACK.ONCE AGAIN AFTER IT WARMED UP IT WOULD NOT MOVE .I HAVE NOT DONE ANYTHING TO IT YET.I WANT TO KNOW MORE BEFORE TAREING IN TO IT.I HOPE YOU CAN HELP ME .I DONT HAVE MONEY ,IF I DID I WOULD GIVE GLADLY ,SORRY
Oct 27, 2009 at 12:07 PM
  • 110,236 POSTS
did the check engine light come on when this happened? If not, the only thing you can do it take the trans apart to see what has been damaged or worn. If it slips when cold and does nothing when hot, chances are the clutches are bad. I assume you checked the trans fluid and it's full.
Nov 9, 2009 at 1:36 AM
