1995 Jeep Laredo STARTER NEEDS TAPPING
249,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEEPGURL10
MY STARTED AND ALTERNATOR WAS TESTED GOOD SUNDAY AT AUTO ZONE BUT NOW MY JEEP WILL NOT START WITHOUT TAPPING STARTER AND KEY IN IGNITION. ALSO THE BATTER SEEMS TO STAY TO THE KEFT AND GRADULY GO TO THE RIGHT. I JUST HAD BATTERY REPLACE 4 WEEKS AGAO AT AUTOZONE
Jan 12, 2010 at 7:48 PM
  • 75,988 POSTS
If you have to tap on it to crank engine over-double check battery connections and at the starter end/also do a voltage drop tests - If okay get the starter load tested again its point to that direction brushes/commutator????
Jan 12, 2010 at 8:00 PM
