1995 Jeep Laredo Overheating????
127,000 MILES • 4 CYL • AWD • AUTOMATIC
KAWI128
In my 95 Grand Cherokeei have replaced the waterpump, radiatior, thermostat, and clutch fan. It was running at about 250 degrees, but it didn't seem to be that hot when i got out of it. So i put an addative in the radiator that was supposed to make the car run cooler and it worked for a few days but then today i drove about 15 miles and the temp was about 215 no hotter and when i got home fluid came out of the cap like it was overheating. Oh i also replaced the radiator cap with a new one which was 18 lbs. (what was on there). I hope you could shed some light on my scene. Thank you.
Sep 17, 2008 at 9:06 AM
MMPRINCE4000
  • 8,548 POSTS
Have a compression test performed to see if you have a headgasket problem.
Sep 17, 2008 at 11:59 PM
KAWI128
i have it was 125lbs in each cylinder but thanx for the help. but if you have any other ideas that would be great.
Sep 18, 2008 at 3:12 PM
MMPRINCE4000
  • 8,548 POSTS
Have the block and cooling system pressure tested, there is a restriction in the system, a leak, or the waterpump is not moving the coolant, or the coolant mixture is not 50/50.
Sep 19, 2008 at 10:59 PM
KAWI128
thank you i changed the exhaust it seemed to help but that was a great idea
Sep 20, 2008 at 12:13 PM
MMPRINCE4000
  • 8,548 POSTS
Great news!
May I suggest that if you changed the convertor, you want to find out why it was clogged.
They generally fail because of a rich/lean fuel mixture, or some type of direct impact.
Just don't want to see you have the same problem again.
Sep 22, 2008 at 12:56 AM
