1995 Jeep Laredo missing on #6 cylinder
PHILCO1995
Engine Mechanical problem
1995 Jeep Laredo 6 cyl Two Wheel Drive Automatic
i have a jeep grand cherokee loredo but cant get it to idle properly number 6 cylinder is not working please help
May 26, 2009 at 2:18 PM
  • 75,988 POSTS
Misfire at no.6 should lead you to check the sparkplug, compression and injector
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
May 26, 2009 at 8:53 PM
