KYLYNNESFAM08
Engine Mechanical problem
1995 Jeep Laredo 6 cyl Four Wheel Drive Automatic
Shut off while driving and now tries to start but won't turn over.I was told it could be the crank sensor or the ignition coil.I just replaced the starter when I first bought it.
Jun 8, 2010 at 12:56 PM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 8, 2010 at 12:59 PM
