1994 Jeep Laredo turn signal failure
1994 JEEP GRAND CHEROKEE LAREDO
200,225 MILES • 6 CYL • 4WD • AUTOMATIC
DONCELLASPAPI
recently my front left turn signal does not work but the rear does work but really fast what could i do. as well as where is the fuse located and can i get a diagram of it . thank you for your time sincerely, J
Feb 5, 2009 at 7:39 AM
  • 110,244 POSTS
Hi:
The fast blinking indicates that a bulb is burned out. If the front doesn't work, that would be the problem. Replace the bulb and it should be fine.
Feb 27, 2009 at 5:29 AM
