1994 Jeep Laredo Rear wheel noise
105,000 MILES • V8 • 4WD • AUTOMATIC
MRWINK
Have a 1994 Jeep Grand Cherokee Laredo. When you turn sharp to park or something, it makes a grinding noise in the rear and it seems like one of the wheels is sticking. It's as if the rear end differential is not "slipping" at all on the inside curve tire side.
Aug 24, 2010 at 11:49 AM
  • 110,248 POSTS
Have you checked brakes? Is the differential fluid full?
Aug 26, 2010 at 12:52 AM
MRWINK
Is it very difficult to check or add to the differential fluid?
Aug 26, 2010 at 1:04 AM
  • 110,248 POSTS
It is very easy. There is a plug on the cover that just pops out. The fluid level should be to the bottom of the opening.
Aug 26, 2010 at 1:21 AM
