due to temperatures...being as cold as they are...im cranking my vehicles daily...and after crankin my jeep yesterday...letting it run little bit ..i went to turn it off and found oil directly under the oil filter...about the size of a saucer plate...and im wondering if the oil filter has expanded and then thawed out after heating the motor...and or the seal in the filter is bad and cant withstand the temps here..in north carolina...around 15 at nite' would i be able to try to turn the filter to tighten up and then see if the leak has stopped...and still drive to get it checked...?...there is no water flowing out at all and i dont think it is the motor...frozen...it did not run hot at all...left it runnin bout 25 minutes b4 i turned it off...thank you for your help and god bless you...
Jan 3, 2010 at 8:21 PM
